Not trying to tick any one off but if you talk to Sensenich they will tell you they do not put any weight in static thrust tests. Static looks good but when a prop is being fed it all goes out the window. Truth is it only matters how it performs in the water, if you are happy with how your boat runs thats all that matters. If you are not satisfied tinker with it till you get what works best for you, no two instances are the same. There is no doubt that there are a lot of people here and a welth of knowledge to pull from but even that will only get you so far.
Static thrust testing has a lot of inconsistancies, for example try a test with same prop and engine @ 98 degrees and do the test @ 90 degrees and you will get considerably different readings. There are to many variables temperature, elevation, and humidity just to mention a few.
Trial and error, no two boats are the same but there is enough help here to hopefully save you a few trials and errors to get you where you need to be quicker.
Great forum guys, this one is getting a lot of attention rather quickly.
