My approach to it all was from a purely mathmatical perspective, kind of like a Car & Driver new car comparrision. Just how might these motor packages perform against the industry standards? Lets dig in.
First off lets establish some constants. I tried to keep it as apples to apples as I could, with the exception being the HP rating of the O-540. All the other motors used would be rated at 400hp.
#1 LS 5.3 or SBC 350ci Iron Block Motor
Weight - 525#
Horsepower - 400
#2 LS1/6 All Aluminum Motor
Weight - 450#
Horsepower - 400
#3 O-540 Aircraft Motor
Weight - 475#
Horsepower - 300
#4 2.4L Ecotec
Weight - 280#
Horsepower - 400
Gearbox on Carmotor Setup - 70#
Gearbox on Ecotec Setup - 60#
Prop on Carmotor Setup - #30
Prop on Ecotec and O-540 Setup - 25#
Now that we have that, I want picked an "average" weight for a typical ride boat that you might find any of these combos on. I picked a ride weight of 1800lbs as the base for an Iron Block CM setup and deducted the difference in the motor setups to get each configurations "standard" weight.
Lets look at the details of each setup and see if we can all agree on some level. Lets say a 3-4 person 14' Open boat with .190 bottom and poly with stainless rigging.
#1 (SBC/LS Iron Block Motor Ride Boat)
Motor - 525#
Gearbox - 70#
Prop - 30#
Rest of Boat - 1175#
Total - 1800#
#2 (LS1/6 Aluminum Motor Ride Boat)
Motor - 450#
Gearbox - 70#
Prop - 30#
Total - 1725#
#3 (O-540 Motor Ride Boat)
Motor - 475#
Prop - 25#
Total - 1675#
#4 (Ecotec Aluminum Motor Ride Boat)
Motor - 280#
Gearbox - 60#
Prop - 25#
Total - 1540#
OK, now lets do the power to weight ratio for each.
#1 (Iron Motor) 1800# / 400hp = 4.5lb per HP
#2 (Aluminum LS) 1725# / 400hp = 4.31lb per HP
#3 (O-540 AC) 1675# / 300hp = 5.58lb per HP
#4 (2.4L Ecotec) 1540# / 400hp = 3.85lb per HP
We still agree on the numbers so far? Ok, now what does this actually mean? Maybe a better way to look at this would be how much increase in performance would one might expect to see. Better yet, what does the reduced weight equate to in actual performance? Lets figure out what the horsepower equivalent would look like. Basically, if I went from an an Iron Motor to an all aluminum LS, would the performance gain be significant enough? What about going from a O-540 to an Ecotec or even crazier...an LS to an Ecotec?!?!?!?
To figure the horsepower equivilant, we'll use a Horsepower to Weight Loss Formula that will tell us what additional HP we would need to achieve the same power to weight ratio, in essence resulting in the same performance. Formula looks like this...
Old Weight / New Power to Weight Ratio = HP Needed
Lets just look at the comparing an Ecotec to the others
#1 (Iron Motor) 1800# / 3.85 = 467.5HP
#2 (Aluminum LS) 1725# / 3.85 = 448HP
#3 (O-540 AC) 1675# / 3.85 = 435HP
#4 (2.4L Ecotec) 1540# / 3.85 = 400HP
What this essentially projects is that given the same theoretical boat, what HP would be needed to make it perform as good as the Ecotec numbers. Granted these are numbers and I'm not suggestion that it would outperform anything. Could be better, could be worse...still a lot of variables out there. So what does this mean. It suggests that an Iron motor setup would need to make 467.5hp, the LS would need 448hp and the O-540 would need to make 435hp in order to have the same power to weight ratio.
Now will it actually perform like that out in the marsh or wherever you ride...good question! There aren't enough of these things running around to really get some conclusive data. How many folks have actually switched from an SBC iron motor, LS or O-540 to an Ecotec and measured the difference? The folks that have made the switch all seem to rave about it, so there has to be SOME truth to the numbers right?
Me being a numbers guy, you might be able to see where I drew my conclusion that these little motors, if proven durable, will absolutely have a place in the airboat industry. At least convinced me enough to build a couple and see how they stack up against a 450HP LS1/6 boat.
Wonder how much this post will
