As we worked with the tests mentioned in the previous post (Driver Adjustable Prop on the Water Walker Concept AirBoat), we were also searching for possible ways to further improve the design principals of airboats in general. Articles were posted as well as general discussions and engineering done to search for possible ways to further improve fuel efficiency extending typical range, enhance safety, reduce noise, and expand service and utility for airboats in general.
Our tests and research led us to believe that there were several major improvements possible in the design/build processes that could achieve major advancements in those stated goals. We have invented, conceived and defined these improvements and designed a new concept airboat that embodies them.
This newest concept airboat is now being built to demonstrate the practicality of these new features. The most dramatic of these new design concepts will be methods to lower the air thrust line. We will also use the improvements recently demonstrated in the Blue Lightning concept boat such as air entrained onto the water planning surface under the airboat and the operator adjustable pitch propeller systems.
A while ago, Plum, AndrewMcD and I spent the morning at Alumitec with Raymond Reel. After discussions and review of our new computer designs, Raymond and his son David agreed to undertake the building of a special hull for this next newest Concept Boat. Andrew continued to work with David Reel on the computer design including several very special features. As of the date of this writing, Raymond & David Reel are nearly complete with the hull (with 5/16” polymer covered bottom) at Alumitec. We will be picking the hull up very soon. This new boat will include:
• A (now proven) air entrainment lip & pocket on the bottom of the hull.
• A newly designed Hyper-Drive system that we call the “Dual-Sync Waterline Drive”.
• A variable geometry transom that allows the “Waterline Drive” system’s vertical center of air thrust to be only 3 feet above the hull bottom. The top of the cage will be only 6 feet above the ground. (Go under highway bridges and store the boat behind a typical garage door height.)
• An approximately 450 HP small block V-8 aftermarket engine mounted low in the boat. (See below)
• A recently designed split-drive transmission with a hydraulically actuated clutch for the “Hyper Drive”. This gearbox with clutch is currently commissioned (serious $ deposits placed) and is now in the “first off” build phase at a nationally known racing specialty transmission company.
We hope to have the new boat completed before Plum is too old to wring it out. Andrew is working overtime on his magic computer and with research to push it along. Plum wants to put a high HP, twin turbocharged EcoTec engine in it. Andrew and I are not sure about that yet. Baseline so far is a MAS V-8 Engine.
Water Walker, as always, “Is working to make airboating better”.
David Wine
David Mosser
Andrew McDermott
