Anybody have one of these used for sale?
TIGO541
Post by TIGO541 »
Anybody using this? Pros and Cons? Its a hub extension that warp drive sells. I need one to set my prop back a couple of inches because its too close to the front of my cage
13-6x7-6 Hamant Ultra-lite,Custom TIG Stainless rigging,1.7 Rotator,Supercharged 480,Electronic Ignition,80 inch 3BLD R,B&S trailer
Tony480
Re: Anybody have one of these used for sale?
Post by Tony480 »
Those are for airplanes if I'm not mistaken. Like experimentals. Not a rank igso540..
terrible ted
Post by terrible ted »
I have one on my 540 but mine bolts to the crank were the gear box use to. I cant say I use one if I did not require one.
move the stand.
Post by Deano »
That looks eerily like the ones that Air Tech Sells.
If they're machined from a chunck of billet, they must be one strong dude.
http://www.airtecinc.us/airboat/index.html
They are about half way down the page.
Call them, they should know how much power they can stand.
HomesteadGator
Post by HomesteadGator »
I have one that is 3'' long. i sent you a pm
FTD RACING
TIGO541
Post by TIGO541 »
HomesteadGator wrote:I have one that is 3'' long. i sent you a pm
Sent you a PM. Thanks. Im not 100% sure i need one yet i have to do some testing to see how much the Saber is gonna flex under full load on this geared monster 8)
air-roberts
Post by air-roberts »
not only just to clear your cage but moving the prop back more also gives more push. it confuses alot of people cause if you check it close then move it back not changing the pitch you lose rpm but gain thrust because the blades get more undisturbed air to it
Air-RobertsImage
New & Used PROPs
WhirlWind prop dealer
TIGO541
Post by TIGO541 »
air-roberts wrote:not only just to clear your cage but moving the prop back more also gives more push. it confuses alot of people cause if you check it close then move it back not changing the pitch you lose rpm but gain thrust because the blades get more undisturbed air to it
Makes sense. Good to know. Thanks
Post by Deano »
Yep, I've seen that with a 4" on a DD caddy. Proves that clean air is the name of the game. After seeing that, it made me start wondering about some of the cages I've seen :shock: Restricting airflow in any way makes a difference. At least in a typical 'I need more power' type of setting, which obviously doesn't always apply equally in all cases. 8)
