water thunder throttle cable
knotright
Post by knotright »
please send me some pictures of how you connected to the throttle body?
knotright
Re: water thunder throttle cable
Post by knotright »
better yet, how you supported the cable prior to throttle body
Waterthunder
Post by Waterthunder »
It depends on the intake which motor do you have.
THE PROOF IS IN THE PROP!
http://waterthunder.com/
321-508-5316
JD
Post by JD »
I'll try to remember to take a pic.
jimslade
Post by jimslade »
I built the bracket for the stock intake and used a Lokar ls1 cable.
jimslade
Post by jimslade »
here is a pic of the pedal end. the cable comes with both ends I needed. My WT has a fast throttle body.
jimslade
Post by jimslade »
here is the pic
knotright
Post by knotright »
Thanks
Tony480
Post by Tony480 »
Here you go
Tony this is what we use from the pic it looks sort of similar to what you have ?
http://www.jamestowndistributors.com/us ... ection+Kit
Rich Andrews
Post by Rich Andrews »
How many xtra HP can I get if I run one of these on my ole iron block 397
T-REX
Post by T-REX »
All of em' Rich!
