Stinger Gear Box
Dan Coffey
Stinger Gear Box
Post by Dan Coffey »
I have a Stinger 2.38 to 1 box and am thinking about going to a 2.68 to 1.
Can I have the gears changed and if so is it worth it? Or do I just sell my box and get another.
Danny Coffey
13' Scorpion 383 Stroker, Stinger gear box, 3 Blade 80" R
12' Jimmy White Step Hull, O 480, 72" 5 Blade Warp Drive
Mudbuddy1554
Re: Stinger Gear Box
Post by Mudbuddy1554 »
I have been told that the housing is to small to go to 2.68 from 2.38. If your box is in great shape you would proly be better off selling it for maybe 2200, and buying a new one. Im having a stinger rebuilt right now and was ruff quoted 1300 if it needed new gears. A new 2.68 soft drive stinger would be just under 3100 tyd. I also know were a 2.68 balistic is that is a demo with less than 10 hours for 2900
2009 14'x8' alumitech, 2.38 stinger, forged 383 stroker, 80" water walker 3 blade maximus
Rainwaterou812
Post by Rainwaterou812 »
Hey how long did you get out of ur box be for you had it rebuilt
Mudbuddy1554
I had a 2.09 to 1 that had 317hours and running strong. Sold it and bought a used 2.38 and got an hour out of it. 3 bad bearings. You may be able to go 2.55 but im not sure. The say boxes should be good for 1300-1500 hours if maintained but ive heard of alot more hours than that
Mudbuddy1554
DynaMarine
Stinger Gear Box
Post by DynaMarine »
The whole housing thing has me baffled. When you go from one gear ratio to the other you are taking one tooth off the drive gear and putting it on the pinion gear. Gear diameter changes but shaft centerlines remain the same. Example, 2.38 ratio is a 49 tooth drive gear and 21 tooth pinion. Going to a 2.68 requires a 51 tooth drove gear and 19 tooth pinion. Gear diameter on both change slightly, but not enough to require a new or different size housing. In an effort to clear the muddy water, we can run any gear from 1.8 through 2.9 in the same housing, and our housing is slightly smaller than a Stinger. Theirs holds 32oz gear oil and ours is 24oz for proper oiling. I would assume you could swap gear ratios and the housing won't be an issue.
That said, it's certainly easier to sell a new box than rebuild an existing box and more profit on new vs rebuild.
Shane Lavalette
President/Owner
DynaMarine Performance Boats
785.218.9449
www.dyna-marine.com
shane@dyna-marine.com
ptillman
Post by ptillman »
MILSAR wrote:The whole housing thing has me baffled. When you go from one gear ratio to the other you are taking one tooth off the drive gear and putting it on the pinion gear. Gear diameter changes but shaft centerlines remain the same. Example, 2.38 ratio is a 49 tooth drive gear and 21 tooth pinion. Going to a 2.68 requires a 51 tooth drove gear and 19 tooth pinion. Gear diameter on both change slightly, but not enough to require a new or different size housing. In an effort to clear the muddy water, we can run any gear from 1.8 through 2.9 in the same housing, and our housing is slightly smaller than a Stinger. Theirs holds 32oz gear oil and ours is 24oz for proper oiling. I would assume you could swap gear ratios and the housing won't be an issue.
I was also questioning the gear box size thing!!! Counld not see why it would not fit.
2014 14x8 JB Hull,421 SBC, Rotator 2.68:1, 82" NGR
12' Thurman, o470 angle valve, 72" WhirlWind Prop (SOLD)
13' Hamant, 383 Chevy, Blue Lightning Drive, 80" R 3 Blade (SOLD)
billybob
Post by billybob »
PM sent
I do all my own stunts!!!!!!
DynaMarine
Stinger Gear Box
Edit
Shane Lavalette
President/Owner
785.218.9449
www.dyna-marine.com
DynaMarine
If the shaft centerlines are the same, and I bet they are, gears SHOULD fit but dunno?!
Shane Lavalette
President/Owner
785.218.9449
www.dyna-marine.com
