Visiting White's Preformance
junglecat
Post by junglecat »
Headed to whites to dyno a motor and bring 2 back . Going to drag races with them Saturday .
Larry Smith built 427 SBC
2.68 Ox Box
82" 3 blade R
450HPFullHouse
Re: Visiting White's Preformance
Post by 450HPFullHouse »
Bring me back one of those 427's you and Larry are running so I can keep up with you guys. :thumbleft:
Alumitec 14'x8', Whites Racing 383 stroker, 2.38-1 stinger, 3 Blade Sensenich R, SS rigging.
Citrus County Airboat Alliance Vice President
blackhornet
Post by blackhornet »
Hey jungle, what do you think of the 383 vs the 427 and which 427 is the best
rather be lucky than good
dyno dan
Post by dyno dan »
I want a 454 pls. Hey 450 what is that you have now a 283?
JB550
Post by JB550 »
Have a great trip. See ya in the marsh this fall.
Jake.R
Post by Jake.R »
I'll jump on the bandwagon, bring me one too! A 427 would bolt right up :D
X2 I'm also curious JC what you think about the 383 vs 427?
14x8 Alumitec SS Rigging
383 Stroker CH-4 2.67
81" 3 Blade S
450HPFullHouse
Dyno it still would not run dry even with a 427. My big old tour boat stays down in the water where a boat should be. LOl :scratch: :stirpot:
supersnake60
Post by supersnake60 »
I just bought one of white performance 427 652 hp with 592 torque and not sure what gearbox not sure what gear 2.37 or 2.50
junglecat
Post by junglecat »
That's what we finished tonite but we went with smaller cc afr heads to change torque numbers. Dyno in morning to see if it worked .
Looked at numbers on a 471 sbc today dirt track motor they were unreal
2.68 Ox Box
82" 3 blade R
OLD MAN JONES
Post by OLD MAN JONES »
Y'all have a good time up there.
PM me the info and details on your dyno session please. I am strongly considering a 427.
Thank you.
LIVING FOR THE FUTURE OF OUR EVERGLADES..
WWW.MACKSFISHCAMP.COM A traditional cultural Gladesman property.
supersnake60
jungle cat what rpm are you turning with R blades with 427 what number pitch
junglecat
Post by junglecat »
Set at 3 it turn 6200 at 3.5 / 5600. Gonna dyno new motor this morning .
2.68 Ox Box
82" 3 blade R
supersnake60
jungle cat thank you for info how dyno go with new motor
junglecat
Post by junglecat »
Learn what we wanted to know about cross drilled cranks , oil pump selection and timing . This wasn't just a horsepower run . We pulled runs at 32 & 34 & 36 & 38 degrees timing. We did a continuous 30 minute run to proove a cross drilled crank airiates the oil at mid and high continuous rpms (3000 & up) . 3 hours on the dyno , leaving with the right crank , oil pump and right plugs, timing and happy happy happy .
2.68 Ox Box
82" 3 blade R
PAINKILLER
Post by PAINKILLER »
There are two different ways to cross drill better be sure you got the right way
MATTHEW 25:35-45 LS 406 82 4bld WaterWalker falcon 2.68 ox box
LS 427 80 3 Bld WaterWalker Maximus 2.68 ox box :rebel:
junglecat
Post by junglecat »
Got rid of the cross drilled. Didn't like what it did with oil pressures. The one I had was fine probably for drag racing but for long runs it would cause pressures to continually drop . Went back to standard crank .
2.68 Ox Box
82" 3 blade R
junglecat
Post by junglecat »
Can really tell the difference with altitude with carb. It's way too rich here but tuned perfect for Fla.
2.68 Ox Box
82" 3 blade R
junglecat
Post by junglecat »
The trip has been great. Got everything done that we wanted. Mr. Whites shop is great and his staff is first class. The numbers they are getting off 93 pump gas are unreal. If you are willing to run racing fuels the sky is the limit. Seen numbers on a sbc 471 that were unreal . The airboat motor program maybe in its infancy but not the knowledge of how to build high performance motors. If you are looking for an affordable powerplant for your boat look no farther than Whites.
2.68 Ox Box
82" 3 blade R
supersnake60
jungle cat do know your Compression ratio on your motor 427 did you dyno it trying to see what to expect from my 427
junglecat
Post by junglecat »
10.5 or 10.6 , it will run on pump 93 , no problem. We were testing with and without cross-drilled crank. We like the constant oil pressures with the non- drilled crank. Pressures vary too much with cross-drilled crank.
2.68 Ox Box
82" 3 blade R
supersnake60
thank you jungle cat for the info !!!!!!!!!!!
junglecat
Post by junglecat »
no problem , wish I could hve stayed and did it for a week . It would have been fun to try different combos of parts. The good thing about it is they have records of all the different combinations they have tried and built. Mr. White has a vast knowledge of high performance. He has been in the game a long time.
2.68 Ox Box
82" 3 blade R
bonecollector
Post by bonecollector »
I emailed Fred 3 days ago about 2 engines I wanted to get built and I haven't heard a word you must have kept them busy.
Sensenich, Ox Drive gear box dealer 386-279-3712
junglecat
Post by junglecat »
Fred was pretty much busy the whole time I was there , I wanted to pick his brain , but he was in and out . I was working with Greg (shop manager) and Larry (head engine builder/ dyno-man). They had 6 , on stands in engine room and at least 20 in waiting. Thunder Valley at Bristol opens at the end of the month and everyone is wanting something freshen up.
2.68 Ox Box
82" 3 blade R
bonecollector
Glad they are busy
