GPU cutdown oil pan/sump
swaffordd
Post by swaffordd »
looking for a cutdown oil pan/sump for a GPU
brotatochip33
Re: GPU cutdown oil pan/sump
Post by brotatochip33 »
Abner at elite airboats in okeechobee makes them.
Packman
Post by Packman »
to save you @ 2 pounds
brotatochip33
not true. there is a giant baffle that is inside that weighs a ton. done right would save you about 15 or so lbs.
gpu rick
Post by gpu rick »
A stock gpu 220 sump weights 22 lbs. I have modified sumps in stock and they weight 10 lbs
Post by John Fenner »
Send me a core, I can build it.
Bamasoflorunner
Post by Bamasoflorunner »
When cut down how many quarts of oil are you looking at?
Same capacity, just lighter.
