Continental G0-300 prop adapter
Kyle12
Post by Kyle12 »
I am Currently finishing up my new build with a Continental G0-300 power plant. I am having a hard time finding a prop adapter for this engine. It’s an 8 bolt pattern but I’d like to get a 6 bolt adapter for it. Does anyone know where I could get one?
Re: Continental G0-300 prop adapter
Post by kwanjangnihm »
Kyle12 - what prop are you going to run? that's a 1.33 gear ratio right?
Kyle12
Post by Kyle12 »
kwanjangnihm wrote:
Mon Dec 16, 2019 2:14 pm
I just got a new Q series from Sensenich. Yes the gear ratio is correct. I had purchased the blade cheap and sent it off to get repaired only to find out it was not repairable. So Darren gave me a good deal on two replacement blades for it. I’ve got a new small and medium hub on my shelf from sensenich that I got as well so either 70in or 72in.
