Stainless or No ?
HomesteadSlide
Stainless or No ?
Post by HomesteadSlide »
I'm fixing to tear down my 11' Taylor sled, everything is getting redone. Right now I have 3 sheets of stainless on the bottom that come right to the chimes, my boat has a true 180 lycoming and will not run dry. I'm trying to make the choice to take it off and steelflex it or leave the stainless. I've heard so many different opinions but need more. I run 3A mostly, I'm not worried about rocks obviously but the stainless is extra protection. Lets hear it !
11' Franny Taylor O-360 sled
:old_glory: :florida:
Union till the day I die !
lycomingkid
Re: Stainless or No ?
Post by lycomingkid »
IMO I would do away with the stainless and go with steel flex to help lighten up the boat but if you are looking for the extra protection keep the stainless or go with poly
1989 Airboat Engineering Stossel runnin a 170av with a possibility of a 200av or a sv540 🤔🤔in the future :old_glory: :rebel: :florida:
Gary S
Post by Gary S »
First of all if your 11 foot boat with a 180 won't run dry something is wrong, that used to be the combination everyone used to run dry. Even with full wrapped stainless it was the boat to have.
That being said it will run the grass better with steel flex, especially the 2000.The down side is it has to be redone every few years.
I picked up a 10 foot Colinger rock boat with a 180 on it a few months ago. It to will have to be totally redone. I have too many projects to start it right now, but it's on the list.
HomesteadSlide
Gary S wrote:
Fri May 22, 2020 6:33 am
It's a strong motor, it will run dry when going, but stopped on dry ground it ain't happening. There are alot of things wrong with the way the boat was built, it's alot heavier than it should be. I will be lightening it up by atleast 100 pounds, new engine stand and cage, guess I will be going with steelflex as well.
Post by John Fenner »
No real need for stainless anymore, unless they open up south of the loop or you plan to run oyster beds, check, you might consider removing the backup plates, but that would be alot of work.
HomesteadSlide
John Fenner wrote:
Wed May 27, 2020 2:31 pm
That's what I was thinking John. Fingers and I are tearing my boat down soon, just wanted the opinions.
