350 DD boat
Barefootduck
Re: 350 DD boat
Post by Barefootduck »
kwanjangnihm wrote:
Sat Feb 22, 2020 3:45 pm
Looking great BFD!! What gauge cable are you using?
#2 thanks
Central Florida,
St Johns area
Barefootduck
Re: 350 DD boat
Battery cables in and started the cage and changed my fuel gauge lol
Central Florida,
St Johns area
Barefootduck
Re: 350 DD boat
Cage
Central Florida,
St Johns area
Barefootduck
Re: 350 DD boat
Gonna need some tweaking but at this point if it looks decent holds the rudders and protects the prop and people from the prop I’ll be happy
Central Florida,
St Johns area
hill
Re: 350 DD boat
Post by hill »
If a bullfrog had a hip pocket he,d carry a pistol to shoot black snakes.
Barefootduck
Re: 350 DD boat
Tweaked the cage and got it even. Think the hoops match good and looks straight. Gonna get the rest of the braces and mounts done tomorrow and possibly rudder mounts. Let me know how it looks.
Central Florida,
St Johns area
Barefootduck
Re: 350 DD boat
Extra pic
Central Florida,
St Johns area
Barefootduck
Re: 350 DD boat
top Is after I straightened it out and bottom is right after I bent the hoop and tacked the shape together
Central Florida,
St Johns area
Re: 350 DD boat
Post by kwanjangnihm »
Coming along nice BFD! What year is the vette?
Barefootduck
Re: 350 DD boat
kwanjangnihm wrote:
Sat Mar 07, 2020 5:35 pm
76 with original 350 block and crank. Different heads and intake though It’s my brothers
Central Florida,
St Johns area
Barefootduck
Re: 350 DD boat
Well got most of the cage put together and bolted the prop on gave er a test run and she launched into the shop lol can’t wait to get the rudders mounted and give it a test run around the yard and see how it’ll run. Think the cage is coming out good.
Central Florida,
St Johns area
Barefootduck
Re: 350 DD boat
Pics that wouldn’t load into original post
Central Florida,
St Johns area
Barefootduck
Re: 350 DD boat
Doess anybody know of a tachometer I could use on the small block 350 that only does up to like 4K rpm? I don’t know how the aircraft engines signal the tach but would be cool to use a 4K rpm tach for this boat
Central Florida,
St Johns area
Re: 350 DD boat
Post by Slidin Gator »
I use ISSPro gauges. They make electronic and mechanical and I have an electronic with a scale to 3,000 RPM on my boat with electronic ignition.
https://www.isspro.com/
Barefootduck
Re: 350 DD boat
Here are two short video clips of the first few test runs. Yes the cage had a little vibration but it isn’t fully welded just tacked together. Also missing a couple mounts. Probably shouldn’t have ran it with the prop but I couldn’t wait. I was sure it was sturdy enough but that is why I didn’t fully rev it up. I’m not sure exactly what I revved it up to to make it move but I know it was less than 2500 for sure. The second video link is the one we’re it moved. But man I missed the sound of that prop.
:thumbleft:
Central Florida,
St Johns area
Barefootduck
Re: 350 DD boat
Rudders mounted. Couple braces on the rudder brackets and and the cage is coming off to fully weld and add the wire and paint then going back on. Maybe next weekend will be the first yard test
Central Florida,
St Johns area
Barefootduck
Re: 350 DD boat
Welding
Central Florida,
St Johns area
Barefootduck
Re: 350 DD boat
Got wire on the gauge. Used #12 grid wire which was cheap. Only $7 for 100ft It took about 225ft and I have to say hand laying ain’t no joke. First time doing it and the grid wire came in a roll not straight peices. I think it looks pretty good and will do the job. Let me know what you think!! It’s kind of like a mix between 3x3 and 3x4-4.5 squares and rectangles. I like it.
Central Florida,
St Johns area
Barefootduck
Re: 350 DD boat
For some reason it’s only letting me post three pictures per post now.
Central Florida,
St Johns area
Barefootduck
Re: 350 DD boat
Finished the cage Friday and Saturday I did a lot of buttoning up. Got it ready to fire up and drove it around the yard and decided to do a maiden voyage. Me and two passengers and it ran pretty good. Planned out fairly quick and actually did not porpoise. It felt like if a wave got it started I would have to speed up to get it to stop but it didn’t start porpoise it on it own. Still need to put my stringer jack bolts in and paint the rudders. All in all it was a good first run and ran good. Untill my ignition module went out. Lol. Now I know to have spare modules and coils just in case. Luckily my buddy towed me back
Central Florida,
St Johns area
Barefootduck
Re: 350 DD boat
Here are some pictures of the cage itself.
Central Florida,
St Johns area
Re: 350 DD boat
Congrats on the maiden voyage BFD! All that hard work is paying off. :thumbleft:
Barefootduck wrote:
Sun Mar 22, 2020 5:43 am
Don't sweat it man, after a few times all CM guys get used to it! :toothy7:
hill
Re: 350 DD boat
Post by hill »
Barefootduck
Re: 350 DD boat
kwanjangnihm wrote:
Sun Mar 22, 2020 9:50 am
Lol so it wasn’t the module the 12v ignition wire going to the coil on the coil side not the harness side broke in half. I wonder why they used solid wire for those prongs rather then stranded. If it was stranded it would never brake
Central Florida,
St Johns area
Barefootduck
Re: 350 DD boat
Put a extra coil on I had at the house and started right up. Wish I would have saw it yesterday could have saved me a tow with a butt connector lol
Central Florida,
St Johns area
