Need Precision Gear Box Broke housing repairable?
RichM617
Post by RichM617 »
Anyone out there have one of these they would like to sell?
Anyone ever try to repair this?
Re: Need Precision Gear Box Broke housing repairable?
Post by Deano »
A picture is worth a thousand words. Where is it broke?
As far as buying one, I'm sure Vaughn has a couple:
http://www.airboatgeardrives.com/1.html
If you are up to the task, maybe he'll sell you a housing? :dontknow:
RichM617
Post by RichM617 »
Thanks for the reply Deano! When I get out to the boat I'll grab a picture.
I"m going to give him a call and see if maybe I can just get the casing itself.
I was hoping someone on this site may have one laying around they don't use and I could put to some good use for them! :)
jeepinocala1111
Post by jeepinocala1111 »
RichM617 wrote:Thanks for the reply Deano! When I get out to the boat I'll grab a picture.
Posting a picture it may be simple as welding it up.
OK I will be the one to ask!
What caused this to crack? There may be another issue to be looking for in this failure unless you dropped it.
firewalkerb3
Post by firewalkerb3 »
I have a precision gear box 2 to 1 hanging on a 383 stoker motor with a 6 blade warp drive. I bought the box new and had it rebuild. A year later it started leaking oil, a lot of oil. Pulled and had it rebuilt again, a year later it broke the shaft off going into the adapter plate. Had it rebuild again, started it today to go riding...bang the shaft snapped again. All but the first time I hauled it to Oviedo to have the work done. Now I going back again to pay again for the same thing. I'm thinking about selling it this time, just to much and I don't trust it.
jeepinocala1111
firewalkerb3 wrote:I have a precision gear box 2 to 1 hanging on a 383 stoker motor with a 6 blade warp drive. I bought the box new and had it rebuild. A year later it started leaking oil, a lot of oil. Pulled and had it rebuilt again, a year later it broke the shaft off going into the adapter plate. Had it rebuild again, started it today to go riding...bang the shaft snapped again. All but the first time I hauled it to Oviedo to have the work done. Now I going back again to pay again for the same thing. I'm thinking about selling it this time, just to much and I don't trust it.
Either you are overworking it to much, it's not being fixed properly, or they have bad material for a shaft to break. Either way that's sad post a few pictures.
This is a very odd situation to have what appears to be 3 failures with one immediately off what sounds like a vendor or factory rebuild. Have you called him back and discussed this with the owner of Percision. There has to be something binding up or off alignment because a 383 with a warp should not be breaking a fairly stout output shaft. They are the lightest duty drive of the big 4 but were built and engineered specifically for your application.
Is there any information that might lead us to better understand why this is happening? Was the boat in a crash, had the prop had a strike to did you have a engine seizure or crank break in the past?
Tony480
Post by Tony480 »
Don't waste your time with it..scrap that garbage and buy an Oxdrive
Gary S
Post by Gary S »
You have a box that has had 3 failures so your going to fix it again and pass it on to someone else, nice.
jeepinocala1111
Gary S wrote:You have a box that has had 3 failures so your going to fix it again and pass it on to someone else, nice.
OR simply fix it right and keep it?
