Excalibur pitch 0540
Airboat propeller discussion.
codachobee
Post by codachobee » Thu Oct 15, 2015 7:37 am
I just bolted of 72 four blade Excalibur prop on my 0540 sv if anyone has any input on what degree I should start the blades at I want to sling it at 2750 and also whats you guys opinion on staggering the blades the tailing bladed a degree more of pitch
WhirlWind Propellers
Re: Excalibur pitch 0540
Post by WhirlWind Propellers » Thu Oct 15, 2015 9:46 pm
Did you get your pitch set yet?
Every motor is a little different, and it depends on where you decide to measure your blade angles along the length of the blade. We typically recommend you measure about 3 to 4 inches in from the end of the blade - in a place you can set your digital angle finder. I would recommend the same blade angles for all blades, and roughly 8 to 10 deg to start. Your target is a full throttle setting of around 2700 to 2900 RPM. Each degree of change in pitch will make about 100 to 200 RPM of change in your full throttle RPM.
I know some like to set a delta between the two blades on each side, and I think it's usually about 2 degrees difference.
Let me know if I can help with anything else.
Sincerely,
Patti
:proud:
Return to “Prop Talk”
