Best prop for 180
Airboat propeller discussion.
Rstuder304
Best prop for 180
Post by Rstuder304 »
Looking for the best overall/ pushing prop for my 180 . Boat has a 5 blade razor x it's a snappy prop but I'm looking for better performance on the dry. Thanks for any advice
diamondback0320
Re: Best prop for 180
Post by diamondback0320 »
What hull? Water walker 68in cypress blades
Rstuder304
It's on a 12ft hamant
diamondback0320
I got a 11.6 diamondback with 160 w poly with the prop I recommended & runs ground great & still good snap
LSX1
Post by LSX1 »
70'' Q
Rich863
Post by Rich863 »
Cypress
:old_glory: :florida:
Rich863
Post by Rich863 »
Cypress
Post by Deano »
Water Walker Cypress Series will give you more dry push. You'd maybe want a 70" though.
Call and talk to them, Plum will know the pros and cons of 68 or 70.
Won't go wrong either way, if you find a deal on one though.
air-roberts
Post by air-roberts »
i prefer the wt narrow 70
Air-RobertsImage
New & Used PROPs
WhirlWind prop dealer
Dirty
Post by Dirty »
What size is your RazorX? Let me know if you wanna sell it. I run an older Powershift 68" Cypress on my 0360AV and it does pretty good.
Jimmy White Square, Cont-Injected Upstack 0540, Stainless
12' Custom Riveted, 0360 Angle Valve, one seater ride boat
diamondback0320
I know everyone has there opinion but I've ran 2 aluminum boats with water walkers & 1 with wt narrow,12ft old bear aluminum w 160 with 70in water walker,11.6 cottonmouth w 180 with a 70in whisper tip narrow,& now 11.6 diamondback with 160 with a 68in water walker,both water walker were cypress blades & imo the water walker was best all around for what I do which is hunt,fish & frog,thats just my experience
Last edited by diamondback0320 on Tue Apr 21, 2015 2:31 pm, edited 2 times in total.
Cmcintosh721
Post by Cmcintosh721 »
I had a 0360 on 12ft bear hull had a 72" h when I bought it tried an older warp drive and then bought a 68" cypress you will lose speed on the water but if you want dry ground grunt cypress was the best on the hill by far
swampsquatch09
Post by swampsquatch09 »
IV got a 70" waterwalker on my 160, if i had 20 more hp it would be 20hp badder. Do it
:texas:
Rstuder304
Thanks for all the input. Sounds like the cypress is a good match for these 4 cyl. I believe my razor x is a 68in If anyone is interested thanks again!
Thunder200
Post by Thunder200 »
68 Cypress for sure.
LSX1
Post by LSX1 »
Sorry SENSENICH I tried, looks like they like the Cypress. LSX1
ptr34
Post by ptr34 »
68 " NGQ all day. I have one u can try.And it will stI'll have top end speed too :D
tons videos on YouTube ptr34
Rich863
Post by Rich863 »
Dnt sleep on a 70 34 paddle eather
Return to “Prop Talk”
