New sensenich ngq vs whirlwind whispertip
Airboat propeller discussion.
Russell0420
Post by Russell0420 »
I'm rebuilding a 12 / 8 Taylor boat with 0470... Just wondering others opinions on what prop to go with... Any help will be much appreciated...
Tony480
Re: New sensenich ngq vs whirlwind whispertip
Post by Tony480 »
72" NGQ
digginfool
Post by digginfool »
Tony480 wrote:72" NGQ
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :thefinger:
Tony480
Post by Tony480 »
Do you have a problem with that digginFOOL? If so we can take care of it...
BUSHHOG85
Post by BUSHHOG85 »
Ngq all day no comparison :thumbleft:
SC 480 13x7'6 HAMANT
520 13' RICOCHET
digginfool
Tony480 wrote:Do you have a problem with that digginFOOL? If so we can take care of it...
You can dish but not take, huh?
SwampCritter84
Post by SwampCritter84 »
2 blade IVO....
Cast Iron Corruption on its way
Hambone79
Post by Hambone79 »
NGQ...
digginfool
For what it's worth, I'd go with the NGQ as well.
fl cracker
Post by fl cracker »
Try them both, see what you think! Whisper tip should be around 10" wide, NGQ is 12". Swamp your killing me with the IVO,I could whittle a prop of of tree bark that would perform better lol
" I have two guns...
One for each of you "
2017 Al David / stroked LS
Russell0420
Thanks for the info!!! Everyone seems to be set on the ngq. Just wanted some input before spending the money!!!
plumcrazy
Post by plumcrazy »
digginfool wrote:For what it's worth, I'd go with the NGQ as well.
have you ran one on your barge :stirpot: 72 signature will get her done call for a price ...
B-White
Post by B-White »
I would try them both....everyone Thats giving you opions have never tried both. Alot of $$$ to take bias opions.
Devil in the Bottle 83 ProMod
Marsh Master Step
Carbon Fiber Rudders by:HAMMERHEAD AVIATION.com
Prop is NOTHING BUT A WHIRLWIND!!!
RAZORX
SwampCritter84
fl cracker wrote:Try them both, see what you think! Whisper tip should be around 10" wide, NGQ is 12". Swamp your killing me with the IVO,I could whittle a prop of of tree bark that would perform better lol
Lol, I had to break the furry somehow...
Bruce
Post by Bruce »
id def give them both a shot because one is better than 500 dollars more expensive than the other i know id want to be sure
12 foot Mamba "The Underdog"
Hog Guts
Post by Hog Guts »
I like my 72 NGQ and I'm not talking about one I haven't spent $2222 on either. It's nice. I haven't tried the others. Get with terry or one of the guys that sells them I'm sure they have demos of both you can actually try out that's what I did... If you can try before you buy you won't have to worry about your choice or how it might behave. Go find out.
ptr34
Post by ptr34 »
i have one u can try. NGQ we can test when u are ready
tons videos on YouTube ptr34
digginfool
:lol: No, not yet, but I'm sold on the idea of winglets on airfoils. Hartzel proved it first, Sensenich proved it to me with my NGR. Obviously, aeronautic engineers have proven it to the airlines; hardly a wing in the fleet doesn't utilize a winglet. The lost drag means more power to turn the prop.
ptillman
Post by ptillman »
The Coast Guard has that style on their rotors as well. Had a long discussion with one of them one time. Pretty cool how it works.
2014 14x8 JB Hull,421 SBC, Rotator 2.68:1, 82" NGR
12' Thurman, o470 angle valve, 72" WhirlWind Prop (SOLD)
13' Hamant, 383 Chevy, Blue Lightning Drive, 80" R 3 Blade (SOLD)
The NGQ benefits the user as a result of the Coanda effect, just look at the Airforce C17 Galaxy it uses winglets also.
digginfool
The Coanda effect is the tendency of a fluid to follow a curved surface. In aeronautics, it is utilized to increase lift by placing jet engines above the wing, thus increasing the velocity of the flow of air over the curved surface of the airfoil and, by extension, increasing lift. Winglets decrease drag by partially blocking the flow of higher pressure air under an airfoil to the lower pressure area above the airfoil, which decreases the creation of wingtip vortices and, thus, decreases drag. You have to remember that a propeller blade is an airfoil. Not only is it an airfoil, but it is an airfoil travelling at tremendous speed, especially at the tip. Any reduction in wingtip vortices will translate into significant reduction in drag. Thus, less drag, more power available to turn the prop. As Thomas Dolby would say; "Science!!"
plumcrazy
Post by plumcrazy »
http://airinsight.com/2012/04/10/wingle ... r-reality/
a little read on winglets ,,,,,,, the winglets i ran on my boat a few years back where pointing the wrong way
any good reason for that 8) my father 2 uncles and a cousin worked for boeing and i have talked to them about this subject and lets just say its a black art :angel4:
digginfool
There is more evidence that winglets, whether on a prop blade or a wing, work. There are exceptions to every rule and all your article does is focus on the exceptions. To its credit, it acknowledges the pros but attempts any way possible to downplay them. I think the comments following the article speak volumes.
fl cracker
I noticed the blow by out of my blow by tube when I had my Q the smoke would flow out the side of the cage. I noticed the winglets are pulling the smoke in towards the Hub. I think the Winglets are gathering more Air and pulling it in.
B-White
Post by B-White »
plumcrazy wrote:http://airinsight.com/2012/04/10/wingle ... r-reality/
:cheers: :cheers: I'm glad to see that I am not the only one that sees the winglets as just a marketing fad. Some people would buy into a prop with holes drilled in it if they were TOLD it was better....lol
Hell, I even bought one at one time. Run it for awhile.Tore the winglets up, cut them off with a portaband and could tell absolutely NO difference... :dontknow:
Marsh Master Step
RAZORX
Locked
Return to “Prop Talk”
