how to pitch a warp drive
Airboat propeller discussion.
Pimp Slow
Post by Pimp Slow »
I know I need a protractor but don't know what kind to get. Also don't know how far to measure the blade to get pitch. Ifsomeone can tell me where to get the protractor from and how to do it I would appreciate it
10' 6" Taylor deckover
0320 s/v lycoming
6 blade warp drive
Just a lil 4 banger
Chaseh
Re: how to pitch a warp drive
Post by Chaseh »
Warpdriveinc.com.
It's so easy a cave man could do it...
happy harold
Post by happy harold »
any hardware store has degree levels. pick a spot---say 4 inches from the end while the airboat and prop blade are level. not complicated.
GeeLeDouche
Post by GeeLeDouche »
happy harold wrote:any hardware store has degree levels. pick a spot---say 4 inches from the end while the airboat and prop blade are level. not complicated.
I do mine right at the tip.. I thought that's where it was suppostu be measured from. ??
DIXIENOURMOUS
Post by DIXIENOURMOUS »
It dont matter where you measure from as long as you measure at the same place on each blade
Id get a digital angle finder there under 100 bucks
2013 AGI-A alumitech IO-540
I like Women like 6.0 powerstrokes.............. always blowin
Dan Coffey
Post by Dan Coffey »
Get the one from Warp Drive it is simple and allows you to do it by yourself. I go about 2" in.
Danny Coffey
13' Scorpion 383 Stroker, Stinger gear box, 3 Blade 80" R
12' Jimmy White Step Hull, O 480, 72" 5 Blade Warp Drive
Return to “Prop Talk”
