Disassemble the distributor (knock pin out of cam drive gear on distributor). Spot weld the mechanical advance pins into place. I have had several summit distributors fail due to the pressed in pins coming loose. Reassemble with proper shimming between case and cam gear to minimize end play, Summit crap is always loose.
I agree on the point of eliminating vacuum advance for now. But vacuum advance will make a frog machine sip fuel.
Describe the hesitation. Does the motor hit a wall for a second and then kick in (vacuum secondary), or do you punch it and the motor falls off for a second and then kicks in (mechanical secondary, not enough accelerator pump).?
I’m guessing mechanical. Make sure accelerator pump linkage is set to max charge. Set secondary linkage to bring them in late, after a good shot from accelerator pump. Try limiting max opening of secondaries, it limits air, adds vacuum which’s adds fuel on secondary. Redneck tune.
That Edelbrock is terrible for your power needs, but I would hesitate to go back to cast iron on the stern. You need to be moving weight forward not back. 1900 to hold plane is not out of line in a 7’ 3” wide hull and the weight you have. Start with 200 lbs of barbells in the nose and see how she runs. If you don’t like, just chunk em.
