To start at the generic beginning, if you have two blades that are capable of holding the motor back, adding another blade and running three is only going to have you running less pitch to use the same power, thus rendering the additional blade un-necessary. On the other hand, if the two blades you were running would not hold the motor back, then an additional blade is definately in order.
The additional drawback to running an un-necessary third blade is increased initial expense, decreased 'snap' and addtional drag. If everything else is a 'push' (pun intended) an advantage of running three blades is the ability to more affordably upraded your prop later if you need to because of engine and/or gear upgrades, because you would already have a three blade hub and the ability to more add more pitch. The way you describe your rig, it doesn't sound like the snap part of it would be an issue, as a prop change will not make a hot rod out of a station wagon.
You are pretty close to, likely beyond the threshold of 2 or 3 blades with the Falcons. I would think that with your gear, if you decide to run a 2 blade, you would want to run the Sirius blades, some folks here speak very highly of them. If your going to run three, then the Falcons would work better. Not so sure about the other blades, but would agree with Patty's assessment.
A lot of times a person already has a hub so there is incentive to use what ya got, but since you'll need a hub to, that isn't really a consideration. If I had the means and was able to buy new, I think I would go with the three blade for the reasons stated. On the other hand, if that's not the case and I found a deal on a 2 blade that was designed to push best at low RPMs, I would buy that in a heart beat and not feel bad about it. You're gonna be smiling anyway after you get beyond the mental grief and do it. 8)
