500 Caddy milky oil?
Lll122
I recently acquired a project airboat with a 500 Caddy dd. I have a lot of work to do to it including installing new poly on the bottom, but I’d like to get the engine going first before I sink too much money into it . The boat has been sitting a while, the engine starts and runs, but the engine oil is milky. I drained oil and refilled, but I’m assuming it has a coolant leak somewhere. Any suggestions for a likely cause of the water intrusion, or what I should check first? Are there common issues with these motors that could cause this? I plan on doing a leak down test on the cylinders, and pulling the intake and changing gaskets….
The engine does not smoke and I don’t notice any bubbling in the coolant…
Any help or tips would be appreciated!
First question is how milky and have you flushed it and changed the oil ?
There can be 5-10 actual issues that cause it but if the boat has been sitting it can be as simple as a cold runner and humidity.
Flush it with a little diesel and start fresh
I had one like that and we just drained the oil and struck out.. was the carb covered ?
