| Author |
Message |
carp slayer
Post subject: corvair motor 140 hp Posted: Mon Feb 08, 2010 10:59 pm |
| Southern Airboat Member |
Joined: Mon Feb 08, 2010 10:52 pm Posts: 29 Location: fitchburg, wisconsin
where do i post to find some parts or is there a for sale section i did not see. i picked up a air boat the other day but the motor needs to be rebuilt it is 1965 corvair motor the 164 larger of the bunch just under the turbo.
_________________ 16' scow 140hp corvair
| Top |
BigJakesrq
Post subject: Re: corvair motor 140 hp Posted: Mon Feb 08, 2010 11:21 pm |
Joined: Mon Jul 13, 2009 8:06 am Posts: 1313 Location: Sarasota, Florida
| Top |
garrett
Post subject: Re: corvair motor 140 hp Posted: Mon Feb 08, 2010 11:25 pm |
Joined: Sun Jan 21, 2007 12:56 am Posts: 116 Location: FLORIDA
clarks corvairs its a good website
_________________ PERFORMANCE IS NO LONGER A THEORY! 904-251-5274 15ft deckover, 620 H.P. 496 wheeler, 2.55 stinger, 3 blade sw (and i need more blades)
| Top |
carp slayer
Post subject: Re: corvair motor 140 hp Posted: Tue Feb 09, 2010 6:33 am |
i did not even see that up there newbe thanks for the info though does any one on here run this motor? if so what size boat. so i have some what of an idea what my end product is going to do like mph, control , and loudness. i have a 16' flat bottom not looking for speed or hp i can't go any where with it here but on the water manly got it to shoot carp and gar.
| Top |
goldhunter_2
Post subject: Re: corvair motor 140 hp Posted: Tue Feb 09, 2010 6:56 am |
Joined: Mon May 23, 2005 6:17 pm Posts: 6330 Location: Port Saint Lucie Fl
you want Torque . you mite also try experimental aircraft sites for corvair parts I know we used them before and there are lots of info and parts once you get to looking. for the airboat it depends on your set up I sold a homemade gear reduction a while back for a corvair to a guy in GA and we used to use the VW big bore kits on the corvairs .
_________________ . Friends don't let friends buy carmotor boats
| Top |
carp slayer
Post subject: Re: corvair motor 140 hp Posted: Tue Feb 09, 2010 8:16 am |
what is the weight of a chevy 350 is it really tippy with that big motor sitting up in the air the boat i got is 16x78 flat bottom with runners. is it worth buildinga diffrent cage and just replacing the corvair motor? the corvair is so light though i don't know what would work better do you?
| Top |
BigJakesrq
Post subject: Re: corvair motor 140 hp Posted: Tue Feb 09, 2010 9:12 am |
In my opinion 16'x78'' is too much hull for a small motor like the corvair. A a nice 350 would be much better. Still keep in mind your not going to be running dry ground with building the motor up a little bit and adding gear/belt reduction. You won't have to worry about tipping. JMO...... then again you bought the boat with the corvair so it had to do halfway okay with it, but I can't see it doing much more than puttin around on a big hull like that. To put it into prospective I'm building a 16'x8' boat right now with a 600hp sbc with a gear reduction, but I plan on going anywhere I want to with it
| Top |
carp slayer
Post subject: Re: corvair motor 140 hp Posted: Tue Feb 09, 2010 9:53 am |
it will only be used to troll at 2 mph most of the time anyway but i here the it was used as a serch and rescue boat in its prime. what do you think i'll get for top speed out of it?
| Top |
Hoosier-Airboater
Post subject: Re: corvair motor 140 hp Posted: Fri Feb 19, 2010 10:37 am |
Joined: Thu Mar 12, 2009 12:00 pm Posts: 203 Location: River Rats of Seymour Indiana
carp slayer wrote: it will only be used to troll at 2 mph most of the time anyway but i here the it was used as a serch and rescue boat in its prime. what do you think i'll get for top speed out of it? My Buddy back in Indy runs a Corvair on a 16 foot aluminum hull, He would run on ground if it was muddy, He told me he had 4 guys in the boat many time going up the river for hunting/fishing trips. He would swear by the little motor
_________________ 10' x 7' Gore Hull/100hp continental 0-200 aircraft engine/3 blade warp drive prop (my little airboat)
14' Combee with 500 D/D Caddie swingin' a 72x38 Fla. Air wide. (the BOSS HOG airboat)
| Top |
carp slayer
Post subject: Re: corvair motor 140 hp Posted: Fri Feb 19, 2010 11:19 am |
thats good to hear i am rebuiling it right now and knowing it moves a boat 16' with 4 guys sounds reassuring. do you know what type of speed he gets out of it or how easy it is to control?
| Top |
Hoosier-Airboater
Post subject: Re: corvair motor 140 hp Posted: Sat Feb 20, 2010 12:45 pm |
carp slayer wrote: thats good to hear i am rebuiling it right now and knowing it moves a boat 16' with 4 guys sounds reassuring. do you know what type of speed he gets out of it or how easy it is to control? The first time I was ever on the stick I was sliding around the edges of the sand bars like a pro, but the end of the 4 guy story he did run a log through the side of it because he said he came around a corner and she wouldnt turn and ran a log clean through the side above the water line, hahaha, It felt fast for me being it was my first time one one, so I couldnt judge a speed for you sorry, It was not real fast but we were getting up the river pretty good,
| Top |
carp slayer
Post subject: Re: corvair motor 140 hp Posted: Tue Apr 06, 2010 9:38 am |
well i got the motor rebuilt. it has good compression. i tested it and not one cylinder lower than 125 psi. timing is right on and cam is set at 0 degrees but i can,t turn over 2000 rpm with the prop on. the prop is directly bolted to the crank. is that about what it should be turning for a motor this size? i have a wood 60" 2 blade prop. it trolls at a perfect speed for shooting carp though so i'm not changing anything if i don't have to. i just want some more rpms for top end.
| Top |
Whitebear
Post subject: Re: corvair motor 140 hp Posted: Tue Apr 06, 2010 12:58 pm |
Joined: Thu Jan 05, 2006 7:49 pm Posts: 8565 Location: Palm Bay, Fl
60X?? What and whose prop is it?
_________________ "The Constitution is not so the government can restrain the people, it is so the people can restrain the government." Patrick Henry The government cannot give anything -- that they have not first taken from someone else.
| Top |
carp slayer
Post subject: Re: corvair motor 140 hp Posted: Tue Apr 06, 2010 2:45 pm |
i have no idea what pitch it is or what brand it looks like there was a sticker on it with what looks like wings. how do i figure out what pitch it is?
| Top |
Whitebear
Post subject: Re: corvair motor 140 hp Posted: Tue Apr 06, 2010 2:48 pm |
Most manufacturers I know stamp it into the hub. Let me get a picture for ya what to look for. Should find something like this:
| Top |
carp slayer
Post subject: Re: corvair motor 140 hp Posted: Tue Apr 06, 2010 3:01 pm |
Well there is numbers stamped there. what i can make out is a something el 60c 32 ra22941.
| Top |
Whitebear
Post subject: Re: corvair motor 140 hp Posted: Tue Apr 06, 2010 5:01 pm |
Sounds like a 60x32 to me then. Might be cool to take a look on the Sencenich site or any of the other prop MFRs and see what they say about a HP rating.
| Top |
carp slayer
Post subject: Re: corvair motor 140 hp Posted: Thu Apr 08, 2010 2:14 pm |
well i found some older post on here and there was a guy running 60x36 prop on a vw 65 hp motor and he was turning 3000 rpm. as for some other postes on corvair motors they are running a 66x32 with rpms at 2800 or so. so i would guess my rpm should be around 3000 at wot.  but i would like a avitar but i can't shrink my pics.
| Top |
cntry141iq
Post subject: Re: corvair motor 140 hp Posted: Thu Apr 08, 2010 9:30 pm |
| Site Supporter - VI |
Joined: Fri Sep 03, 2004 8:31 pm Posts: 3882 Location: bradenton florida
Then pm whitebear and he will fix ya up he is da fixer upper around here
_________________ Don't waste your time ... it is the only thing you can't get more of
| Top |
Whitebear
Post subject: Re: corvair motor 140 hp Posted: Thu Apr 08, 2010 9:53 pm |
Email me the one ya want for an avatar and Ill shrink it for ya so it will work. I'm here to help man.
Be sure to put in the body of the email you want it shrunk for an avatar.
| Top |
carp slayer
Post subject: Re: corvair motor 140 hp Posted: Fri Apr 16, 2010 8:43 am |
so i put some bigger jets in the carb and it runs a lot smoother but still will not turn past 2000rpm i have turned the distributer advanced and retarded and not any change. what am i over looking here? do you run the vacume advance on your motor or is it off? i seen another set up on ebay and i don't see a vacume hose on his. well thanks for the help so far it is not exactly as i thought it would be for driving it but not bad.
| Top |
R L Williams
Post subject: Re: corvair motor 140 hp Posted: Fri Apr 16, 2010 11:37 am |
Joined: Tue May 15, 2007 10:13 am Posts: 2011 Location: Alachua
Carp slayer, from experience with corvairs on airboats, the accelerater pumps on carbs working well is very important. The engine being horzontally opposed, will rev smoothly, but slowly with only one pump working, makes a big differnce in acceleration snap.
_________________ Member of the over the hill gang.
| Top |
carp slayer
Post subject: Re: corvair motor 140 hp Posted: Fri Apr 16, 2010 11:54 am |
i have the after market intake that runs to one holly carb the take off / accelleration is great it just will not rev past 2000 rpm.
| Top |
cntry141iq
Post subject: Re: corvair motor 140 hp Posted: Fri Apr 16, 2010 4:24 pm |
probably too much prop
| Top |
SHABA
Post subject: Re: corvair motor 140 hp Posted: Fri Apr 16, 2010 6:53 pm |
| Site Supporter - III |
Joined: Mon Dec 18, 2006 9:25 am Posts: 358 Location: San Antonio
I use to run a 140Corvair you should get about 2800 RPM the prop with he wings could be what I had was a Banks and Maxwell they were the main ones that made props for Corvairs and VW's. Mine was on a 14' and would run pretty good... would not run dry but would go approx 25-30 mph. went over a lot of thick water lilies with it... did not have a problem with it but make sure you use the fan to keep it cool when it is idling... It is prone to overheating. Man that sure was a long time ago... The Distributor should have vaccume advance make sure it is hooked up to VENTURI VACUUM and not PORTED! If it is hooked to ported that is your problem!!! I hope that helps...
_________________ TAA 511 Hunt with your kids today and not for them TOMORROW!
| Top |
