SouthernAirboat.com   Pictures & Wallpapers   Classifieds   Forum   Weather & Water Data   Store   Calendar   Airboat Directory   Site Support
By accessing or using this Site, you agree to be bound by the terms and conditions as stated in the SouthernAirboat.com Rules & Terms
It is currently Tue Sep 07, 2010 11:26 pm
Post new topic Reply to topic  [ 10 posts ]
Author Message
 Post subject: LASER HULLS
PostPosted: Mon Feb 08, 2010 7:54 pm
Offline
I NO I BOUGHT A LASER BUT WHATS SO SPECIAL ABOUT THEM I SEEN ALOT OF PEOPLE WANTING THEM AND ALWAYS SAYING GOOD THINGS ABOUT THEM I SEE NOTHING SPECIAL ABOUT IT MY SELF
_________________
WELP ITS A (BOY) AGAIN DUE FEB
AIRBOATS AND GIRLS I NO WHY I STAY BROKE
 Profile
 Post subject: Re: LASER HULLS
PostPosted: Mon Feb 08, 2010 7:56 pm
Offline
james if that is chris grease monkey old rig that is a galliou
 Profile
PostPosted: Mon Feb 08, 2010 8:40 pm
Offline
GILLEO HAS A LASER MOLD.THERE ARE A BUNCH OF DIFFRENT MAKERS OF A LASER STYLE BOAT NOW.
 Profile
PostPosted: Mon Feb 08, 2010 8:42 pm
Offline
The laser mold has been passed around for years now there seems to be 3 levels of quality 1) The actual original laser solid built good hull (has a pvc pipe molded into the the top of the sides for support) 2) Several hand laid good thick tough hulls made of about the same quality maybe a touch less as the original. 3) Crappy sprayed hulls not very tough and wear out fast.
But, they all ride good and handle very well in tight trails very 'predictable' as some people would put it.
You can really tell the diff in quality from one to the other.
 Profile
PostPosted: Mon Feb 08, 2010 10:23 pm
Offline
THATS RIGHT I CALLED AND TALKED WITH THEM THEY MAKE GILLEO/LASER SAME THING FROM WHAT I UNDERSTAND
MY TITLE SAYS GILLIEO MY BUDDYS BOUGHT A HULL GILLIEO LASER AND HIS TITLE SAYS LASER NO DIFFERENCE IN THE APPEARANCE
FISH YES THATS CHRIS RIG I NOW HAVE
_________________
 Profile
PostPosted: Thu Feb 11, 2010 12:22 am
Offline
I'm going to be in the market for 2 new hulls as I'm tired of leaks/fiberglass work, etc.
1- A 12 foot fiberglass that will have a Lycoming 180. Boat currently runs great dry, but could handle better and has a very short transom so it will take on water really easy. My 13 year old has also started driving this boat and it will be his boat over time so I'd like something that runs good, but is also safe/tough and will last. I'm hearing the 12 foot Rivermaster is 'back', but I haven't seen one. I had been hearing really bad stuff about the 'new' Rivermasters. I also hear debates regarding which Laser (Ocala guy vs. Gilleo). Haven't really heard about Jimmy White having anything 12 foot in a ride boat. Thoughts?
2- 13'6" hull for an AV 0540. Currently on a real old Cottonmouth with polymer, stainless rigging, stainless grass rake (i.e. heavy boat). It's a barge and after driving the 4 cylinder it's almost no fun, but when I've got 3 or 4 people it's a necessity. I hear they may have the 'old' Freedomcraft coming back. Also considering the same things outlined in #1 above regarding the different Laser hulls. I do hear good things about Jimmy White, but mostly from the guys that want to go fast. I haven't heard about how well they run dry or last. I'd probably start with slick bottom, but almost everyone I ride with has gone to polymer due to the past really dry times. I also want this hull to last 'forever' as I have no plan to sell, etc. It is also a ride boat that will need to run dry with people. Thoughts?
Thanks
 Profile
PostPosted: Thu Feb 11, 2010 8:01 am
Offline
If you want both boats "to last forever" you might consider aluminum - new or used, no fiberglass hull stands up to the ground like aluminum and poly does.
_________________
A I R B O A T
 Profile
PostPosted: Thu Feb 11, 2010 9:06 pm
Offline
have been running laser for about 15 years, slide a lil and cut alot, depends on what you want...good all around hull
 Profile
PostPosted: Thu Feb 11, 2010 9:43 pm
Offline
James has STARS... :shock: ...Good job buddy...
My brother and I both have a laser hull, both boats ride and handle nice and the looks are pretty familiar but the strength between the two is not even close.
He has a Gillieo and i have a "Tater Chip" with a slick bottom applied to it...
 Profile
PostPosted: Thu Feb 11, 2010 11:32 pm
Offline
Thanks all for the feedback on Lasers. It appears Gillieo has some supporters. I will stick with fiberglass although I realize nothing lasts forever... Do note that this last comment is not meant to draw out any political commentary.
 Profile
Display posts from previous:  Sort by
Users browsing this forum: butch, cypresswamper, plumcrazy and 4 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
 Copyright 2010 SouthernAirboat.com, Inc. All Rights Reserved
Contact | Support SouthernAirboat.com
