New prop??
Oleboy87
New prop??
Post by Oleboy87 »
Going to get a new prop soon. I am currently running a 70" 3 blade H and I am wanting to get a 2 blade I have heard a lot of good reviews on the new NGQ I was debating on that or the whirl wind whisper tip what do you guys think?? I am running a sv 540 with 9:1 pistons.
billybob
Re: New prop??
Post by billybob »
Try the 72" I run the 74" NGQ and love it. It is close to the best of both worlds. Call Brian at Quick Slick he sells them. His number is 863-581-9710.
I do all my own stunts!!!!!!
Oleboy87
Re: New prop??
Post by Oleboy87 »
Thanks! Im mainly wanting good low end push.
mMontana
Re: New prop??
Post by mMontana »
I have been running the 74" whisper tip on a IO520 and great prop extremely tough prop but was also thinking about that NGQ but a little nervous about the winglets are they fragile?
fl cracker
Re: New prop??
Post by fl cracker »
NGQ all the way. Whisper tip is the same as the Q. Decent push on the bottom , sucks everywhere else!
" I have two guns...
One for each of you "
2017 Al David / stroked LS
Oleboy87
Re: New prop??
Post by Oleboy87 »
Ya, I think it will be the NGQ for me! I don't care about going fast I just want something with good push!!
fl cracker
Re: New prop??
The blade width is 12" , it pushes damn good!
ptr34
Re: New prop??
Post by ptr34 »
Winglets are solid
tons videos on YouTube ptr34
Tony480
Re: New prop??
Post by Tony480 »
The winglets are plenty strong enough to chop up oak limbs. I tested them out today. You won't be disappointed with the NGQ I promise
Re: New prop??
I got a 76 NGQ sitting in my back room waiting for the motor to be done.
480 you serious about them winglets being that tuff? Is the prop everything they say or what? Any negatives?
Re: New prop??
Post by kwanjangnihm »
Tony now that you've tested the 72, 74 & 76 NGQ, which one are you going to stick with?
Can you comment on each one? Snap, cruise, ground running & wot! thanks
:rebel:
Tony480
Re: New prop??
Post by Tony480 »
SWAMPHUNTER45 wrote:I got a 76 NGQ sitting in my back room waiting for the motor to be done.
What do you think I was joking? I had some oak limbs about 2" in diameter get in to it today and there wasn't a mark on it.
Tony480
Re: New prop??
Post by Tony480 »
kwanjangnihm wrote:Tony now that you've tested the 72, 74 & 76 NGQ, which one are you going to stick with?
:rebel:
I'm sure I will keep the 76" on. They all cruise good and have tremendous low end but the 76" is an animal down low. It doesn't need to be turned hard to be effective. In fact at 2850 you are over spinning it. I run it like that last weekend and it had lots of low end grunt but was loud as hell after 2750 or so. Put some pitch in it yesterday and was turning it 2750 and it still has great bottom end and not near as loud. Still playing with the pitch and motor angle. I'll keep ya posted. But to spin a 76" with any kind of pitch, it's gonna take a strong 6 cylinder that's for sure
Scarecrow
Re: New prop??
Post by Scarecrow »
2 in oak limbs c,mon :drunken: :scratch: :rebel:
Ugmo#1
Re: New prop??
Post by Ugmo#1 »
Tony, What's your pitch mark on your NGQ 76" at 2750 RPM
Tony480
Re: New prop??
Post by Tony480 »
I don't have pitch marks on mine. They were the first blades made. I use a digital protractor to aet the pitch. But I have 8° degrees in it.
billybob
Re: New prop??
Post by billybob »
Tony480 wrote:I don't have pitch marks on mine. They were the first blades made. I use a digital protractor to aet the pitch. But I have 8° degrees in it.
Sounds about right. I'm turning the 74" at 11.5 degrees out at the end of the blade and I'm turning it 2850. I don't have marks on mine either. Is it worth grabbing a long hub and trying it?
mMontana
Re: New prop??
Post by mMontana »
Toney, mine is a injected stock rebuilt 0520 angle valve I was told they are same as 0540 angle valve injected right at 300 hp I have the room to go either 74" or 76" I just want ground running power don't care about speed I just have heard a lot of good things about these NGQ but up till now it didn't seem like changing from whisper tip to a Q or power shift made that big of a difference for amount of money spent but the talk is this new NGQ really does seem like its worth it better, than all the rest?
Tony480
Re: New prop??
Post by Tony480 »
Yep billybob that's what I was turning my 74". Our numbers have been about the same. I'm going to put some more pitch in the 76" and try it again. If you just are worried about the low end hill running get a 76" if your motor will spin it
Ugmo#1
Re: New prop??
Post by Ugmo#1 »
Tony, thanks for the info
billybob
Re: New prop??
Post by billybob »
Tony480 wrote:Yep billybob that's what I was turning my 74". Our numbers have been about the same. I'm going to put some more pitch in the 76" and try it again. If you just are worried about the low end hill running get a 76" if your motor will spin it
Going to see if I can get a long hub from Brian and try it out.
Re: New prop??
Bill let me know when you test out the 76 and I'll meet up with you! :rebel:
billybob
Re: New prop??
Post by billybob »
kwanjangnihm wrote:Bill let me know when you test out the 76 and I'll meet up with you! :rebel:
Ten four man. Ill get with ya.
Oleboy87
Re: New prop??
Post by Oleboy87 »
Spoke with Brian this morning and got one ordered, I can't wait!!!!
Re: New prop??
awesome! :rebel:
what model and size hull you running?
