Real Time Thrust Tests with Complete Boats
CarMotorBarge
Re: Real Time Thrust Tests with Complete Boats
Post by CarMotorBarge »
anvil wrote:I was just informed by our project manager that a q blade was .8 quieter than the wood prop if it makes any difference. in the interest of being politically correct.
Anvil,
Did you do sound measurements at different RPM levels? At WOT I would expect the car motors to be louder because they are making more HSP. I strongly doubt that anybody is going to throw away their carbon fiber prop and go buy a woodie tomorrow. So analysis of the data needs to be done to understand what is really happening. I only want a good woodie for romancing the wife and not for riding airboats. :lol:
CarMotorBarge
anvil wrote:
akblackdawg wrote:Anvil, you mentioned sound level and earlier somebody else mentioned sound level all being about the same, I know both WW and Sens both make props that they advertise as being super quiet. Were any of those tested on car motors and did they appear quieter then some of the older style props. I here people on here comment occasionally that their prop is so quiet they can talk easily over it at cruise speeds, that is info I am looking for. Bud
all the wider props are quieter to the ear a cruise once you get them up to max they are all about the same. I run my race -ride step hull with eight sabers and a 2.68 box all day with no ear muffs same with my ride boat four 82 inch r s as long as i am not flat out they are fairly quiet. when I was running my two blade water walker with the tall gear belt box it was noisy because it was spinning up near max all the time. all props are noisy when aproaching max rpm. the quietest prop we tested was a wood prop on an air craft engine. The narrow props produce a sound that is much higher pitched and produces the illusion of more noise. the fact is the sound on all the props tested was very near the same in decible level at wide open. The slower you can turn a prop and get a good result is optimum for quiet operation. cntry has been doing this sound testing for years he has probubly made the quietest air boat built. We ran a bunch of combinations of motors props and exaust systems they all varied in noise until pushed to the max. Wide blades and car motors with good muflers are the key to quiet at moderate speeds. There is no magic quiet prop. It seems the solution is to turn as much prop as possible at a low rpm. Wide blades and lots of gearing and a very good exaust system to quiet the motor.
I definitely agree with all of this. I will also throw in "light as possible". Lower weight allows you to get lower RPMs. Do a search on this website for sound testing. You will see that WT kicked everybodys butt at cruise RPMs at a sound competition. He was using S blades on a really light hull with 2 ordinary mufflers. He also beat everybody at WOT and he had lots of HSP on that boat.
yobee
Post by yobee »
If someone smarter than me will chime in, isn't .8 pretty significant? I thought than one decibel difference was perceived as double the sound ie.88 decibels is twice as loud as 87 to the human ear
Anyone? Trying ok learn not talking sh!t lol
plumcrazy
Post by plumcrazy »
heres a link that will help explain percepsion of sound
http://www.gcaudio.com/resources/howtos/loudness.html
HuntingBigun
Post by HuntingBigun »
Great graph Plum :D
Bigun
http://www.krvsa.com
Rich Andrews
Post by Rich Andrews »
another reason not to play a french horn... :lol:
CarMotorBarge
Does anybody know how the "Perceptions of Increases" was calculated? It says that a change of 10 decibels is perceived as twice as loud, but other sources on the web say that an increase of 10 decibels is 10 times louder and an increase of 20 decibels is 100 times louder. I am trying to understand the differences. Thanks.
Whitebear
Post by Whitebear »
When calculating decibels, every 3 DB is double the power in the signal.
If you don't normally work with Decibels its confusing as hell, so I will try to find a better logical technical writeup on line. I'll cut it in here after I find it for ya. I am assuming you are specifically asking about dB SPL (sound pressure level) so thats what I will look for.
Excellent dB SPL writeup:
http://trace.wisc.edu/docs/2004-About-dB/
Perception of Loudness (20dB = 4x)
Interestingly, our perception of loudness is not the same as sound pressure level. Although the actual formulae
is somewhat complex, as a rough rule of thumb, an increase of 10db SPL is perceived to be approximately twice as loud.
Thus a 20 Db gain would seem to be about 4 times as loud.
And a 40 Db gain would seem to be about 16 times as loud.
I think this perception is actually what the question was. Keep in mind the 10 dB is a rule of thumb not an actually calculated level for perception to be twice as loud.
yobee
Post by yobee »
Got it Scotty. For some reason I had 1 decibel in my head, but it's 10. I also understand that is just a guideline. So the original .8 decibels I questioned isn't that much of a difference.
Duane Scarborough
Post by Duane Scarborough »
Here's how I've been taught:
Every increase of 3 dB represents a doubling of sound intensity, or acoustic power.
So, I guess that a 1 DB increase would be about 1/3 louder. I don't know...
It's still pretty significant.
Duane
Hull: Airboat Pros MiniPro 116 / Frog Spit on the bottom
Rigging: Stainless Steel-side by side seating
Motor: Teledyne 4A084-4
Carb: Solex H30/31
Reduction: Arrow Prop 1.73:1
Prop: 67" Whirl Wind Mini Prop
Speed: unknown yet
CarMotorBarge
Thanks plumcrazy and whitebear. I definitely learned something.
Yobee,
You need to stop asking such difficult questions. It makes me think too hard. :lol:
yobee
Post by yobee »
CarMotorBarge wrote:Thanks plumcrazy and whitebear. I definitely learned something.
Yobee,
Why do aircraft boats run so much better than carbarges? hehe
Thanks for the ride saturday, hadnt been out in a while lol
anvil
Post by anvil »
intel, company, and fish begin to stink after three days. I hope the exact numbers are posted sooner than later. all the boats ran between 98 and a little over 102 decibles at full throttle. The difference in the wood prop and the q carbon fiber was a .8 . A difference you could not determine with the human ear. at least not with the ones I am using. once posted the information should clear things up I am working from memory i dont have the numbers infront of me. Some times all three brain cells dont hold hands.
The company of men who seek the truth is much prefered to those who think they have it
Ride boat 14 ft Don Davis Davis sled iron sbc
eyecrazy
Post by eyecrazy »
can't wait its like christmas come on quit teasing us
Roxy7430
Post by Roxy7430 »
Sorry for the delays! We are trying to test, play a little and most of us have jobs that take way too much time! I am going to provide some initial thrust numbers in this post. There will be much more detail to follow inclusive of spreadsheets and graphs. Big Casino is working on his fancy reports and making final adjustments as we speak.
The results I am going to share now are just "test as you drive" numbers with no effort to get the max thrust number. We did have some boat owners modify their motor or prop to improve thrust numbers after the initial pull.
I will provide some basic info about each boat and you can go to the picture gallery for a picture of each boat. (The pics were posted by Big Casino).
After some of the boats were “tweaked” the order changed slightly. Some owners chose not to make any changes
Boat Thrust
C 1423
B 1365
G 1319
A 1310
D 1309
E 1077
I 876
H 841
F 740
Test Boat A
15' Scorpion
383 SBC
2:68 Rotator
526 HP @ 6000 RPM per Dyno sheet
3 blade R
4" SS cage
S by S driver, triple up front
Air ride
Test Boat B
15' Scorpion
Modified 351W (bored and stroked)
Approx 12.5:1 compression
HP: Unknown but 500+
2:67 belt drive
3 blade R
4" plus SS rigging
Brand new boat not quite finished
Test Boat C
16' Scorpion
496 BBC (Voss Racing)
547 HP @ 5100 RPM per Dyno Sheet
Staggered 8 blade saber
1.91: 1 Belt Drive
4" SS Cage
Single driver, double up front
Test Boat D
16' Jimmy White
427 SBC by MAS
602 HP @ 6000 RPM per Dyno Sheet
4 Blade R
2:68 Stinger
4" SS Cage
Test Boat E
12.5' Hamant Ultralight
EFI, LS1
Horsepower unknown: Approx 500
3 Blade R
2:68 Stinger
2 x 4 SS Cage
S by S driver, no front seats
Test Boat F
14' "Jimmy White"
Motor: 220 GPU
HP: Unknown
Prop: 74" Water Walker - 2 Blade
2 x 4" SS Cage
S by S driver, Triple up front
Test Boat G
16' Jimmy White
6.2 L Waterthunder
500 HP (no Dyno)
3 Blade R
2:38 Stinger
4" SS Cage
Air Ride
Test Boat H
15' Marty Bray
0-520 gitsu Conversion
Estimated @ 300 hp
74" 2 Blade "Q"
4" SS Cage
S by S Driver, removable front seat pkg.
Test Boat I
RiverMaster 1450
0-540 parrallel valve
HP Unknown
72" NGH - 3 Blade
4x4" SS Cage
S by S driver, double up front
Jim Allen, President
Go Ballistic Airboat Co
352 463 3960
jim.a@pharma-mgt.com
bondsman
Post by bondsman »
interesting the 3 blade r made more thrust that the 4 blade r.and only 10lbs of thrust between differences.
nomad41
Post by nomad41 »
Boat G what was the prop set at? That is closest to my set up. Thanks,Jim and bet this was fun to do all this testing.
Treasurer FAA
Svcliche@yahoo.com
C1gator
Post by C1gator »
Man this is some interesting stuff..I can see where some 2.68 guys might be scratching there heads....Really good info and thank you for sharing it.......
poobought
Post by poobought »
nomad41 wrote:Boat G what was the prop set at? That is closest to my set up. Thanks,Jim and bet this was fun to do all this testing.
Im going on memory alone but I believe 2ish.
HuntingBigun
very cool stuff, thanks for all your efforts :D :D
Bigun
poobought
Post by poobought »
C1gator wrote:Man this is some interesting stuff..I can see where some 2.68 guys might be scratching there heads....Really good info and thank you for sharing it.......
You aint kidding, It really suprised me. The Water Thunder with the 2.38 showed us all up. But we will be testing that same motor with a 2.68 so we will know the real differance. Wait till you see the cruise numbers with the 2.38 and also the 1.9 belt.
Come on Dave you know your motors better than anybody take a guess what the differance will be between the 2.38 and 2.68. I must admit I hope the 2.68 does a little better.
Whitebear
Post by Whitebear »
I cant make heads nor tails of this. I don't see one test boat with the RPM the thrust was measured at. Without that info the thrust produced is mostly a useless number for any comparison. I'm just lost I guess.
I keep trying to see what RPM the props are turning for the thrust measured. Maybe that part will show on the graphs and charts. If so, then I am jumping the gun right now.
yobee
Post by yobee »
Its pretty cool yall sat down and did this, lots of work for sure. Itll be cool to sit back and read all the info when ya get it ready, no rush on my part. Im just offended that big casino let a straight valve 540 out push him... :oops: :lol:
Waterthunder
Post by Waterthunder »
So all the small blocks had 2.68's accept the WaterThunder which had a 2.38. I will say when propped and pitched correctly the 2.68 makes more thrust. There are several issues that effect all this and we have way to much RnD time an money to give it up. But we must be doing something right if a 4 year old 500HP motor with a 2.38 ratio out trusted the other small blocks that had 600HP plus dyno sheets and 2.68 ratios. I wish they would have done one of our 600HP's with a 2.68 I know for a fact our 600HP with a 2.68 on average makes around 400lb's more of thrust then a 500HP with a 2.38.
THE PROOF IS IN THE PROP!
http://waterthunder.com/
321-508-5316
muffled500hp
Post by muffled500hp »
Roxy7430 wrote:Sorry for the delays! We are trying to test, play a little and most of us have jobs that take way too much time! I am going to provide some initial thrust numbers in this post. There will be much more detail to follow inclusive of spreadsheets and graphs. Big Casino is working on his fancy reports and making final adjustments as we speak.
Boat Thrust
C 1423
B 1365
G 1319
A 1310
D 1309
E 1077
I 876
H 841
F 740
Test Boat A
15' Scorpion
383 SBC
2:68 Rotator
3 blade R
4" SS cage
Air ride
Test Boat B
15' Scorpion
2:67 belt drive
3 blade R
4" plus SS rigging
Test Boat C
16' Scorpion
1.91: 1 Belt Drive
4" SS Cage
Test Boat D
16' Jimmy White
427 SBC by MAS
4 Blade R
2:68 Stinger
4" SS Cage
Test Boat E
EFI, LS1
3 Blade R
2:68 Stinger
2 x 4 SS Cage
Test Boat F
14' "Jimmy White"
Motor: 220 GPU
HP: Unknown
2 x 4" SS Cage
Test Boat G
16' Jimmy White
6.2 L Waterthunder
500 HP (no Dyno)
3 Blade R
2:38 Stinger
4" SS Cage
Air Ride
Test Boat H
15' Marty Bray
Estimated @ 300 hp
74" 2 Blade "Q"
4" SS Cage
Test Boat I
RiverMaster 1450
HP Unknown
72" NGH - 3 Blade
4x4" SS Cage
Is it possible to post what the engine RPM's were at peak thrust?
Keith ~~
Modern Performance Engines, LLC
Custom built engines for airboats, hotrods, mud trucks, buggies, circle track and drag racing!
352-282-6407
MPEKeith@gmail.com
www.facebook.com/modernperformanceenginesllc
