How to remove kway reduction
Sweet water 13
Postby Sweet water 13 » Wed Jul 18, 2012 12:58 am
Pulled my engine out of my boat after it locked up, and I'm trying to remove my kway reduction housing from engine to see if the reduction is locked up. I removed the six bolts from bell housing and was able to see shaft, but can't tell how it's attached, is there a secret to removing it? :dontknow: :louisiana:
Sweet Water 13
Ronnie's 15 x 71/2, 3/16 aluminum hull, 502, 2.38 belt,3 blade R series ,3/8 poly,extreme duty swamp boat
selphdanny
Re: How to remove kway reduction
Postby selphdanny » Wed Jul 18, 2012 1:10 am
Did you pull the bolts out of the flywheel?
Sweet water 13
Postby Sweet water 13 » Wed Jul 18, 2012 12:45 pm
No, I did see a few bolts on the flywheel looking under the bell housing, I can get to them , but being I cannot rotate the engine r the reduction idk if I can reach the top ones from underneath. Is this the flex plate? Is this what connects the two together ?thx for the help :scratch:
Sweet Water 13
Dixiedog60
Postby Dixiedog60 » Wed Jul 18, 2012 3:16 pm
Yes it connects them. you may have to pull your motor apart on the stand to the point you can rotate it or pull them as a unit remove the oil pan and take the rods loose from the crank. If the reduction unit is whats locked up I am not sure whats your best option ? See if you have and bearing materials in the oil of both units and that should be a tell on where you have a problem.
Freedom is Abridged by Silent Encroachment.---James Madison
bondsman
Postby bondsman » Wed Jul 18, 2012 3:43 pm
You need a shot gun, ky jelly, a stick of dynomite ,one wrench,and a monkey in a hat. But not necessarily in that order.
Sweet water 13
Postby Sweet water 13 » Wed Jul 18, 2012 5:02 pm
Thx, I got it apart, I can see some homemade wrenches in my future. Gear reduction turns free, engine is locked up. On to an engine rebuilder :banghead:
Sweet Water 13
Users browsing this forum: Coastslider, Scarecrow and 6 guests
