timing on gpu 470 conv.
ezdevil
Post by ezdevil »
live in highlands county and need timing done on a 220 470 conversion. who is reputable and can do it locally?
Re: timing on gpu 470 conv.
Post by John Fenner »
If you are referring to magneto timing you can do it easily. Take out #1 sparkplug turn engine over till you get compression stroke and piston to top dead center, the crankshaft studs should be dead level, next mark the flywheel to centerline of case. Now depending on your ring gear count to the left 11 teeth if you have a fine tooth ring 9 for a coarse tooth. Then move it back to this mark and you will be at 25* before TDC. Next remove the sight plug on the magnetos then the point cover plate, rotate the mag armature till you see a painted bevel tooth on the gear through the sight hole, plus observe the cam on the points as it should be just opening them, this sets the mag @ #1 and is ready to put into the engine, once on the engine turn the mag slightly to where the points just barely start to break open and lock the mag down, you can get a critical setting by using an ohm meter to the points but it isnt really needed.
Comanche-pup
Post by Comanche-pup »
Then repeat for second mag, that was a very good right up John
GMAC 76
Post by GMAC 76 »
PM SENT got everything to do it
Rob k
Post by Rob k »
Gmac76 will take care of ya,good guy,he works on my cousin's 480
